What are instrument transformers?
Instrument transformers are used in connection with the measurement of voltage, current, power and power in alternating current circuits. There are mainly two reasons for the use of instrument transformers in measurement:
To extend (multiply) the range of the measurement instrument
To isolate the measurement instrument from a high-voltage line.
In power systems, levels of currents and voltages handled are very high, and therefore it will affect the measuring instrument, so the direct measurement is not possible. In such a case, instrument transformers can be effectively used to step down the voltage and current within range of the existing measuring instruments of moderate size.
There are two types of instrument transformers:
- Current transformers (CT)
- Potential Transformers (PT)
Current transformers (CT):
The primary winding of a current transformer is connected in series with the line carrying the main current. The secondary winding of the CT, where the current is many times stepped down, is directly connected across an ammeter, for measurement of current; or across the current coil of a wattmeter, for measurement of power; or across the current coil of a watt-hour meter for measurement of energy; or across a relay coil.
Potential Transformers (PT):
Potential transformers or PTs are used in such cases to operate voltmeters, potential coils of wattmeters, relays and other devices to be operated with high-voltage lines. The primary winding of the PT is connected across the high-voltage line whose voltage is to be measured and the measuring instruments are connected across the secondary of the PT. For all these purposes, it is essential that the secondary voltage be a definite fraction of the primary voltage, and in some applications, they need to be in the same phase as well.
