Why is it important to use mass flowmeters?
Flow measurements are important in industrial automation, and there many flow meters available in the market. In food industries and health industries, it is important to measure that how much amount of fluid flown into the process to ensure the quality of the product. While commonly flow meters measure volumetric flow. Mass flowmeters can measure both mass and density as well.
Mass flow meters are commonly used in Health industries, food industries, Chemical industries
How a Coriolis mass flowmeter works?
Coriolis mass flowmeter works on Coriolis effect. A Coriolis meter is constructed with U-tube, Drive coil and sensors assembly. While all flowmeters measure the volumetric flow of fluid, Coriolis meter measures the mass flow.
In the Coriolis meter, the flow is split into two paths and made to pass though hanging two tubes. When there is flow through the tubes hang stationary.
When there is flow through the channel the fluid splits and half of the fluid pass through each tube. The drive coil attached to the tubes makes the tubes to oscillate in opposite direction.
Flow tubes start to oscillating opposite to each other. Electromagnetic sensors attached to each tube produce sine waves with respect to the oscillation of the tubes.
When there is no flow through the tubes, sine waves produced by the sensors will be in phase. When there is a flow through the tubes then the tubes start twisting. Due the twisting in the tubes, the sine wave produced by the sensors will have a phase shift
The Phase shift between the waves produced by the two tubes in microseconds are proportional to the Mass flow through the tubes. Greater the phase shift greater will the mass flow rate.
And the Frequency of oscillation of the tubes is proportional to the density of the flowing liquid. The microprocessor associated with the sensors converts the Frequency and Phase shift into Density and Mass flow.
