Why don’t use the Wrong Fuse Amperage?
Fuses protect your electrical system. They are there to keep it safe against
- Overloads circuits and
- Short circuits.
However, utilizing the wrong amperage might lead to major problems:
Using a Higher Amperage Fuse
- Allows excessive current to flow.
- Can harm cables, sensors, and possibly causes fire.
- The circuit is no longer effectively protected.
Using a Lower Amperage Fuse
- Blows easily, even under typical load.
- Causes unpleasant faults and frequent replacements.
- This makes the circuit unreliable & unstable.
How to Detect a Bad Fuse?
Here’s how to see if a fuse has blown.
Step 1: Visual Inspection
- Remove the fuse from the fusebox.
- Check out the metal strip inside.
- If the fuse is burned or damaged, it is defective.
Step 2: Use a Multimeter
- Switch the multimeter to continuous mode.
- Touch the probes to both ends of the fuse.
- Beep (or) low reading indicates a good fuse.
- No sound or continuity indicates a blown fuse.
- Replace blown fuses with the same amperage rating (Ex: 15A fuse with another 15A).
