In residential areas of United States, using solid wire for electrical wiring is preferable for several reasons making it superior to stranded wire.
Advantages of Using Solid Wire in Homes
Current Capacity
Cost-Effectiveness
Durability and Stability
Lower Voltage Drop
Ease of Termination
Less Susceptibility to Corrosion
Current Capacity
As compared to stranded wire of same equivalent AWG rating, the solid wire conducts more current.
This addition of air between different strands of a stranded wire reduces overall dimensions but increases resistance, and hence lowers gross current carrying capacity.
Cost-Effectiveness
There is normally a tendency of solid wire to be cheaper than stranded wire.
The fact that this type of wire features a single core renders it especially affordable and accessible to homeowners who are putting primary importance on cost-consciousness.
However, as far as constructional superiority and resistance to mechanical harm is concerned, the solid wire is preferable to the stranded wire.
It also keeps its shape more effectively, which makes it ideal for fixed installations when movement is limited.
This durability keeps off instances of developing breaks or failure within the wiring system.
Lower Voltage Drop
This may be attributed to the fact that solid wires have a lower resistance than the stranded wires, and this make them suitable for the longer distances normally observed in residential wiring applications.
Ease of Termination
Solid wire is easier to terminate hence providing easier connection which in a way are easy to install.
Solid wire is preferred by electricians to work on junction boxes and outlets because of their ease of connecting to a circuit26.
In this aspect, solid wires provide better exterior corrosion Vs stranded wires making them more lasting used at homes.
