What is Zigbee and how does it work?
Zigbee is a low-power, wireless communication protocol designed for smart home devices, industrial automation, and Internet of Things (IoT) applications. It operates on the IEEE 802.15.4 standard, primarily in the 2.4 GHz frequency band, and is known for its low energy consumption, making it ideal for battery-operated devices.
How Zigbee Works:
- Network Topology: Zigbee networks can use star, tree, or mesh topologies. Mesh is the most common, allowing devices (called nodes) to communicate with each other and extend the network’s range by passing data through multiple hops.
 - Device Roles:
- Coordinator: The central device that starts and manages the Zigbee network. There is only one coordinator per network.
 - Router: These devices extend the network by passing messages between devices.
 - End Device: Simple, low-power devices that communicate through routers or the coordinator but don’t relay data themselves.
- Communication: Zigbee uses a lightweight communication protocol, which allows for short message transmission and makes it efficient for simple tasks like turning lights on/off or sending sensor data.
 - Security: Zigbee employs 128-bit AES encryption for secure data transmission.
 - Range and Scalability: Zigbee has a typical range of 10-100 meters, but the mesh network allows this to be extended as data hops through intermediate devices.
Zigbee is widely used in smart lighting, HVAC control, security systems, and industrial monitoring due to its reliability, low energy use, and ease of integration into large networks.
