The integration of an inverter to a UPS can be the practical approach of handling power fluctuations particularly in the regions where voltage swings are frequent.
However, there are a few points to remember when considering safety, capability and various difficulties.
[color=#ff7700]Functionality and Setup [/color]
[color=#CF2E2E] Basic Configuration[/color]
The normal configuration means direct the inverter to the UPS inputs so as to ensure that the UPS provides output power to the connected load whenever the grid supply is off.
The configuration would look like this:
Grid Power → Inverter → UPS → Load
This setup can somewhat reduce problems like the voltage swell during power outages, as the UPS is capable to respond faster than the inverter in majority of the cases.
[color=#CF2E2E] Switching Time [/color]
However, comparing a UPS with an inverter one must identify the switching time is much faster with a UPS.
A UPS normally has a switching time of less than 10 milliseconds while an inverter normally has switching time of about 300- 500 milliseconds.
This is especially disadvantageous when dealing with sensitive electronics because the delay implies a potential/potentially damaging period of stasis the UPS can be advantageous in this configuration.
[color=#CF2E2E] Load Considerations[/color]
One should also ensure that the inverter used in UPS system and load can support the power needed for the UPS and the load.
If the output of the inverter is not adequate to meet the UPS’s greatest demand, the UPS will act unpredictable or even stop working altogether.
[color=#ff7700]Safety and Risks [/color]
[color=#CF2E2E] Potential Issues [/color]
Still, there are some issues, which can trace back to this configuration. Many users provide good results when operating with this configuration.
Ex: if the inverter is incompatible with UPS, then the former might act as a heat sink or inverter might get damaged.
Furthermore, the UPS may not regulate the power received from the inverter well if the inverter’s output does not have a stable, clean wave form
Ex: Using a modified sine wave inverter while the UPS unit was designed for a pure sine wave inverter output.
[color=#CF2E2E] Battery Life[/color]
Installation of a UPS to an inverter can also assist in enhancing the life span of the UPS by easing the load on its battery in regular operations.
The UPS can function as load leveling, taking care of the power demand to run routine activities and the inverter comes in handy in cases of extended power outages.
- You can also follow us on [color=#1E00A3]AutomationForum.co[/color], [url= https://www.facebook.com/instrumentation.control][color=#1E00A3]Facebook[/color][/url] and [url= https://www.linkedin.com/showcase/81532759/feed/posts/][color=#1E00A3]Linkedin[/color][/url] to receive daily Instrumentation updates.
- You can also follow us on [color=#1E00A3] ForumElectrical.com [/color], [color=#1E00A3] Facebook [/color] and [color=#1E00A3] Linkedin[/color] to receive daily Electrical updates.
