Multimeter's Functions
Multimeter’s Functions
1). Automatic Voltage
2). AC Voltage & Frequency
3). Milli Voltage
4). Continuity
5). DC Current
6). DC Voltage
7). Resistance
8). Diode & Capacitance
9). AC Current & Frequency
10). Min/Max
11). Hold
12). Range
13). Function
14). Brightness
15). Volt Alert
16). LoZ
17). Current Socket (Red Probe)
18). Common Ground
19). Voltage & Resistance Socket (Red Probe)
1). Automatic Voltage: Automatically detects and measures AC (or) DC voltage for ease of use.
2 ). AC Voltage & Frequency: Measures alternating current voltage and frequency with high accuracy.
3 ). Milli Voltage: Detects low voltage levels with precision for sensitive applications.
4 ). Continuity: Tests circuit continuity with an audible alert for uninterrupted connections.
5 ). DC Current: Measures direct current flow, essential for battery and DC circuit analysis.
6 ). DC Voltage: Accurately measures direct current voltage across components.
7). Resistance: Determines resistance values in ohms for troubleshooting circuits.
8 ). Diode & Capacitance: Tests diode functionality and measures capacitance for component evaluation.
9 ). AC Current & Frequency: Measures alternating current and its frequency for AC systems.
10). Min/Max: Records minimum and maximum values over time for performance monitoring.
11). Hold: Freezes the display for convenient reading of measurements.
12 ). Range: Allows manual selection of measurement ranges for specific tasks.
13). Function: Rotates to select different measurement modes (e.g., voltage, current).
14 ). Brightness: Adjusts screen backlight for visibility in various lighting conditions.
15). Volt Alert: Non-contact voltage detection for safety during inspections.
16 ). LoZ: Low impedance mode prevents false readings from ghost voltages.
17). Current Socket (Red Probe): Input for current measurements, fused at 10A for safety.
18 ). Common Ground: Reference point (Black probe) for all measurements.
19 ). Voltage & Resistance Socket (Red Probe): Input for voltage & resistance measurements, rated at 600V.
The Fluke 117 True RMS Multimeter is a versatile tool for electricians and engineers providing accurate measurements across multiple parameters.
Its robust design and safety features make it ideal for industrial and field applications.
