Key Steps for Preventive Maintenance on UPS Systems
Step-1: Regular Inspections
Perform visual examinations of the UPS system for signs of wear & tear, corrosion, & other potential problems. Make sure all connections are secure & there are no apparent indications of damage.
Step-2: Battery Maintenance & Replacement
Batteries are a key component of every UPS system. Regularly test the voltage and capacity of the batteries & replace them as required. To avoid premature aging, keep the battery surroundings clean & at the appropriate temperature.
Step-3: Cleaning & Environmental Control
Dust & debris can accumulate within the UPS system, causing overheating & component failure. Keep the system clean and ensure appropriate airflow. Maintain the environment at the correct temperature & humidity levels.
Step-4: Firmware Updates & Testing
Updating the UPS firmware ensures compatibility with new technologies & resolves any known faults. To ensure that the system is working properly, execute system tests on a regular basis, such as load testing and runtime calibrations.
