QDB is used for third party device configuartion and DCS logics are build in Control Module(CM): Method for configuring the data transfer: · Consider the configured Flag with name “OPD” in a CM called “TEST”. · Now create a QDB point. · The channel for this point is a modbus channel with port type as LANVendor without any Port name. · The controller for this point is a modbus controller where we can leave the IP address as blank. · Now we need to enter the CM name and the function block and the parameter name in the PV Source Address of the point as shown in the attachment. · Now once we download the QDB channel, controller & points, the PV of the point will be following the CM Flaga value
You may also try OPC. Check out this Benefits
Regards…
yes it is possible to transfer data from honeywell to some other plateform such as schnieder DCS. we did this in recent days.
