To determine the relationship between no-load EMF (electromotive force) & terminal voltage in an alternator with a minimal power factor, we must examine the phasor diagram and voltage equations in the alternator under these conditions.
In an alternator, the no-load EMF (E0) is the voltage created by the rotating armature when no load is attached to it.
This voltage is caused by electromagnetic induction.
When a load is attached to the alternator, the armature current (Ia) flowing across the armature winding generates an armature response ampere-turns that counteracts the main field ampere-turns. The armature reaction effects reduce the resultant air-gap flux, resulting in a terminal voltage (V) that is slightly lower than the no-load EMF (E0).
At a high power factor (near unity), the armature current (Ia) lags behind the no-load EMF (E0) by a minor angle (δ). In this case, the phasor diagram will be expressed as follows:
The terminal voltage (V) is defined as
- The vector sum of the no-load EMF (E0) &
- The armature resistance drop (Ia x Ra),
where,
Ra represents the armature resistance.
V = E0 – (Ia x Ra)
Rearranging the equation yields:
E0 = V + (Ia x Ra)
The armature resistance drop (Ia x Ra) at a leading power factor causes the no-load EMF (E0) to be somewhat greater than the terminal voltage (V), as seen in this equation.
The difference between E0 & V is usually minimal, particularly in alternators with low armature resistance. As the power factor approaches unity (δ → 0), the armature resistance drop decreases and the no-load EMF (E0) approaches the terminal voltage.
