Electromagnetic flowmeters are perfect for measuring the flow rate of any conductive liquid. These meters are extremely accurate and provide reliable flow measurements. Working Principle of Electromagnetic Flow Meter The functioning principle of the electromagnetic flow meter is based on Faraday’s Law of magnetic induction defined as follows: E= k x B x D x V The signal voltage (E) produced across any conductor moving at right angles across a magnetic field (B) is proportional to its velocity (V). Two diametrically opposed, internally mounted measuring electrodes measure the voltage induced within the fluid. The induced voltage generated by the magnetic coils is proportional to product of magnetic flux density, electrode distance (D), and fluid flow velocity (avg). Advantages
- No Moving Parts: Mag meters have no mechanical components, reducing wear and tear and minimizing maintenance.
- High Accuracy: They offer precise flow measurement, typically within ±0.2% to ±0.5% accuracy.
- Wide Range of Applications: Suitable for various conductive fluids, including water, wastewater, slurries, and chemicals.
- No Pressure Loss: The unobstructed flow tube ensures minimal energy loss.
- Durability in Harsh Conditions: Resistant to corrosive and abrasive fluids, making them ideal for demanding industrial environments.
- Versatility in Pipe Sizes: Available in diameters ranging from DN6 to DN2200, allowing flexibility across different pipeline systems.
- Stable and Reliable Readings: Strong anti-interference capability ensures consistent performance even in challenging electromagnetic environments.
- Capability for CIP/SIP Systems: Suitable for cleaning-in-place (CIP) and sterilization-in-place (SIP) operations, making them ideal for food and pharmaceutical industries.
- High Temperature Tolerance: Can measure fluids up to 180°C.
Applications
Electromagnetic flow meters are widely used in industries requiring accurate liquid flow measurement, including:
- Water and Wastewater Treatment: Used for municipal and industrial wastewater management due to their ability to measure flow in conductive and solid-laden fluids.
- Food and Beverage Industry: Ideal for measuring dairy products, juices, and other conductive liquids in hygienic conditions.
- Chemical and Petrochemical Industry: Suitable for monitoring corrosive and aggressive fluids in process control systems.
- Pharmaceutical Industry: Used in batch processing and sterile environments.
- Pulp and Paper Industry:Measures flow of pulpy fluids and slurries with high precision.
- Mining and Slurry Transport:Ideal for measuring abrasive slurries in mineral processing.
- Power Generation:Helps in cooling water and other liquid flow monitoring in power plants.
- Agriculture and Irrigation:Used for monitoring water distribution and optimizing irrigation efficiency.
