Rabert
1
General Requirements
- IS – 732 – Code of practice for electrical wiring installations (System voltage not extending 650 volts)
- IS – 900 – Code of practice for installation and maintenance of Induction Motors
- IS – 1271- Classification of insulting materials for electrical machinery and apparatus in relation to their thermal stability in service
- IS – 1646 – Code of practice for fire safety of buildings (general) Electrical Installations
- IS – 1866 – Code of practice for maintenance of insulating oil.
- IS – 1882 – Code of practice for outdoor installation of public address systems.
- IS – 1886- Code of practice for installation and maintenance of Transformers
- IS – 1913- General and safety requirements of electric lighting fittings
- IS – 2032- Graphical symbols used in electric technology.
- IS – 2165- Guide for insulation coordination
- IS – 2274- Code of practice for electrical wiring installations (System voltage exceeding 658 volts)
- IS – 2309- Code of practice for the protection of buildings and Allied structures against lightning.
- IS – 3034 – Code of practice for fire safety of industrial buildings – Electrical generating and distributing stations.
- IS – 3043 – Code of practice for earthing
- IS-3072 – Part -1 Code of practice for installation and maintenance of switchgear (System voltage not exceeding 1000 volts)
- IS – 3106 – Code of practice for selection, installation and maintenance of fuses (voltage not exceeding 650 volts)
- IS – 3638 – Application guide for gas-operated relays.
- IS – 3646 – Code of practice for interior illumination.
- IS – 3716 – Application guide for insulation coordination – Equipment located in hazardous situations.
- IS – 3842 – Application guide for electrical relays for AC system.
- IS – 4004 – Application guide for non-linear resisted type lightning arrestors for AC system
- IS – 4146 – Application guide for voltage transformers.
- IS – 4201- Application guide for current transformers.
- IS – 5571- Guide for selection of electrical equipment in hazardous area.
- IS – 5572 – Classification of hazardous areas for electrical installations.
- IS – 5780 – Intrinsically safe electrical apparatus and circuits.
- IS – 5908- Method of measurement of electrical installations in buildings.
Switchgear
General
- IS – 375 – Marking and arrangement for switchgear bus-bars, main connections and auxiliary winding.
- IS – 694 – Part 1 PVC insulated cables (for voltages up to 100v) with copper conductors.
- IS – 1248 – Direct acting electrical indicating instruments.
- IS – 2147 – Degrees of protection provided for enclosures for low voltage switchgear and control gear.
- IS – 2208 – HRC cartridge fuse links up to 650 V.
- IS – 2705 – Part I, II & III – Current transformers.
- IS – 3156 – Part I, II & III – Voltage transformers.
- IS – 3202- Code of practice for climate proofing of electrical equipment.
- IS – 3231 – Electrical relays of power system protection.
- IS – 4047- Heavy duty air break switches and composite units of air-break switches and fuses for voltages not exceeding 1000 volts.
- IS – 4237 – General requirements for switchgear and control gear for voltages not exceeding 1000V.
- IS – 5987 – Code of practice for selection of switches (voltage not exceeding 1000V).
6.6 KV
- IS – 335 – Insulating oil for transformers and switchgear.
- IS – 2516 –Part 1 – Sec.2 Alternating current circuit breakers – Requirements and tests for voltage ranges 1000 to 11000 volts.
- IS – 3427 – Metal enclosed switchgear and control gear for voltages above 1000 V but not exceeding 11000 V.
415 Volts
- IS – 722 – AC electricity meters.
- IS – 1951- PVC sleeving for electrical purposes.
- IS – 2516 – Part 1- sec.1
- Part II/Sec.2- AC circuit breakers – requirements and tests for voltages not exceeding 1000 V.
- IS – 2419 – Dimensions of electrical indicating instruments.
- BS – 4752 – Circuit breakers of rated voltage up to and including 1000 volts and 1200 volts dc.
- BS – 6231 – PVC insulated cables for switchgear wiring.
- IEC – 157 – Low voltage distribution switchgear circuit breakers.
M.C.C
- IS – 1554 -Part I PVC insulated (heavy duty) electric cables for working voltages up to and including 1100 volts.
- IS – 1822 – AC motor starters of voltage not exceeding 1000 volts.
- IS – 2959 – AC contactors of voltage not exceeding 1000 V.
- IS – 3961-Part II recommended current ratings for PVC insulated and PVC sheathed cables.
- IS – 5124 – Code of practice for installation and maintenance of AC induction motor starters (voltage not exceeding 1000V).
Inverters
- IS – 391 – Mains transformers for electronic equipment.
Transformers
- IS – 2026 – Power transformers.
- IS – 2099 – High voltage porcelain bushings.
- IS – 3070 – Lightning arrestors for AC systems.
- IS – 3637 – Gas operated relays.
- IS – 3639 – Fittings and accessories for power transformers
Motors
- IS – 325 – Three phase induction motors.
- IS – 4691- Degrees of protection provided by enclosures for rotating electrical machinery.
- IS – 4722 – Rotating electrical machines
Batteries
- IS – 1652 – Stationery cells and batteries, lead-acid type (with plante positive plates).
- BS – 440 – Stationery batteries
Cables
- IS – 1554 -Part I & II PVC insulated (heavy duty) electric cables for working voltages up to and including 1100 volts and for up to 33 KV.
- IS – 1753 – Aluminium conductors for insulated cables.
- IS – 3961 – Part II – Recommended current ratings for cables.
- IS – 3975 – Mild steel wires, strips and tapes for armouring cables.
- IS – 5819 – Recommended short-circuit ratings of high voltage cables.
- IS – 5831 – PVC insulation and sheaths of electric cables
Alternators
- IS – 7132 – 1973 Guide for testing synchronous machines
- IS – 5422 – 1996 Turbine type generators
- IS – 7306 – 1974 Methods for determining synchronous machine quantities from tests.
