Basics of SCADA HMI scripting
Basics of SCADA / HMI scripting.
Number of SCADA / HMI devevlopment softwares are available in markert nowadays . The basics of scripting is same irrespective of manufacturer . I would like to give some brief idea about scripting.
Different types of Data types used in SCADA/HMI Scripting
Numeric Data String Arrays Etc…
Arithmetic operators used in SCADA / HMI scripting
^ Exponention
  • Negation
  • Multiplication / Division % Modulus Division
  • Addition
  • Subtraction ++ Incrementation – Decrementation
Relational operators used in SCADA/ HMI Scripting
== IS EQUAL TO
Greater than < Less than = Greater than or equal to <= Less than or equal to != Not equal to
Assignement Statement
SET TO
Measn Variable = Expression
Flow Control Statement used in SCADA / HMI Scripting
IF - THEN statement FOR-NEXT Loop WHILE Loop BREAK Statement CONTINUE EXIT
FOR NEXT loop
Used to execute a list of statements a given number of satement
Sysntax for FOR - NEXT Statement
FOR = TO /* Statement lsit goes here */
NEXT []
Example :
FOr x = 1 TO 10 STEP 2 Print X // Print odd numbers NEXT
IF - THEN
Conditional statement
IF statement is true it will execute the expression 1
Else it will execute expression 2.
Example
If A=0
THEN B= C
ELSE B*C
END IF.
BREAK Statement
Used to get out of a FOR NEXT or WHILE loop immediately
EXIT STATEMENT
Used to stop a script
Share more about SCADA / HMI Scripting
Plese share more information about SCADA scripting
