ANSI (American National Standards Institute) protection codes are a system of categories that specify the amount of protection given by safety equipment and devices, particularly personal protective equipment (PPE).
These codes ensure that the equipment fulfils particular safety standards, which protect against hazards such as impact, chemical exposure, & electrical threats. The codes are widely utilised in many industries to ensure worker safety & compliance with regulatory standards.
1 – Master Element
2 – Time delay Starting or Closing Relay
3 – Checking or Interlocking Relay
4 – Master Contactor
5 – Stopping
6 – Starting Circuit Breaker
7 – Rate of Change Relay
8 – Control Power Disconnecting Device
9 – Reversing Device
10 – Unit Sequence Switch
11 – Multi-function Device
12 – Overspeed Device
13 – Synchronous-speed Device
14 – Underspeed Device
15 – Speed – or Frequency, Matching Device
16 – Data Communications Device
17 – Shunting or Discharge Switch
18 – Accelerating or Decelerating Device
19 – Starting to Running Transition Contractor
20 – Electrically Operated Valve
21 – Distance Relay
22 – Equalizer Circuit Breaker
23 – Temperature Control Device
24 – Volts Per Hertz Relay
25 – Synchronizing or Synchronize-Check Device
26 – Apparatus Thermal Device
27 – Undervoltage Relay
27s- DC under voltage Relay
28 – Flame detector
29 – Isolating Contactor or Switch
30 – Annunciator Relay
31 – Separate Excitation
32 – Directional Power Relay or Reverse Power Relay
33 – Position Switch
34 – Master Sequence Device
35 – Brush-Operating or Slip-Ring Short-Circuiting Device
36 – Polarity or Polarizing Voltage Devices
37 – Undercurrent or Underpower Relay
38 – Bearing Protective Device
39 – Mechanical Condition Monitor
40 – Field (over/under excitation) Relay
41 – Field Circuit Breaker
42 – Running Circuit Breaker
43 – Manual Transfer or Selector Device
44 – Unit Sequence Starting Relay
45 –DC over voltage Relay
46 – Reverse-phase or Phase-Balance Current Relay
47 – Phase-Sequence or Phase-Balance Voltage Relay
48 – Incomplete Sequence Relay
49 – Machine or Transformer, Thermal Relay-OLR
50 – Instantaneous Overcurrent Relay
50G - Instantaneous Earth Over Current Relay (Neutral CT Method)
50N - Instantaneous Earth Over Current Relay (Residual Method)
50BF - Breaker failure
51 – AC Inverse Time Overcurrent Relay
51G- AC Inverse Time Earth Overcurrent Relay (Neutral CT Method)
51N- AC Inverse Time Earth Overcurrent Relay (Residual Method)
52 – AC Circuit Breaker
52a- AC Circuit Breaker (CB) Position (Contact Open when Breaker Open)
52b- AC Circuit Breaker (CB) Position (Contact Closed when Breaker Open)
53 – Exciter or DC Generator Relay
54 – Turning Gear Engaging Device
55 – Power Factor Relay
56 – Field Application Relay
57 – Short-Circuiting or Grounding Device
58 – Rectification Failure Relay
59 – Overvoltage Relay
60 – Voltage or Current Balance Relay
61 – Density Switch or Sensor
62 – Time-Delay Stopping or Opening Relay
63 – Pressure Switch
64 – Ground Detector Relay
64R - Restricted earth fault
64S - Stator earth fault
65 – Governor
66 – Notching or Jogging Device
67 – AC Directional Overcurrent Relay
68 – Blocking Relay
69 – Permissive Control Device
70 – Rheostat
71 – Liquid Level Switch
72 – DC Circuit Breaker
73 – Load-Resistor Contactor
74 – Alarm Relay
75 – Position Changing Mechanism
76 – DC Overcurrent Relay
77 – Telemetering Device
78 – Phase-Angle Measuring Relay or “Out-of-Step” Relay
79 – AC Reclosing Relay (Auto Reclosing)
80 – Flow Switch
81 – Frequency Relay
82 – DC Reclosing Relay
83 – Automatic Selective Control or Transfer Relay
84 – Operating Mechanism
85 – Communications, Carrier or Pilot-Wire Relay
86 – Lockout Relay/Master Trip
87 – Differential Protective Relay
88 – Auxiliary Motor or Motor Generator
89 – Line Switch
90 – Regulating Device
91 – Voltage Directional Relay
92 – Voltage and Power Directional Relay
93 – Field Changing Contactor
94 – Tripping (or) Trip-Free Relay( Trip Circuit Supervision Relay)
95 – For specific applications as other numbers are not suitable
96 – Busbar Trip Lockout relay
97 – For specific applications where other numbers are not suitable
98 – For specific applications where other numbers are not suitable
99 – For specific applications where other numbers are not suitable
150 – Earth Fault Indicator
AFD – Arc Flash Detector
CLK – Clock or Timing Source
DDR – Dynamic Disturbance Recorder
DFR – Digital Fault Recorder
DME – Disturbance Monitor Equipment
ENV – Environmental Data
HIZ – High Impedance
