Why Wrong I/O List Created Major Commissioning Delay?
An EPC contractor was executing a large refinery automation project involving more than 2500 instrumentation signals connected to a new DCS and Safety Instrumented System. During the commissioning phase, engineers discovered that several analog input channels configured in the PLC and DCS did not match the actual field wiring. Some pressure transmitters were configured as digital inputs, while multiple shutdown switches belonging to the Safety Instrumented System were mistakenly assigned to the normal process control system.
Operators also noticed that several control valves were responding incorrectly during loop checks. A few fail close valves were configured as fail open in the control logic. In addition, many HART enabled transmitters were listed only as standard analog signals without communication requirements. The marshalling cabinet wiring became confusing because the signals were not grouped properly by process unit, voltage level, or hazardous area classification.
The project team later found that multiple revisions of the I/O list were circulating between instrumentation, electrical, and automation departments. Some engineers were working with outdated spreadsheets while others modified newer revisions without proper document control. Because of these inconsistencies, procurement ordered incorrect I/O cards and several control panels required rewiring during FAT and SAT activities.
The commissioning delay occurred because the I/O list is the foundation document for automation system engineering in EPC projects. Any mistake in signal classification, fail safe definition, or revision control directly affects control system design, marshalling, cabinet wiring, PLC programming, and commissioning activities.
Incorrect classification of analog and digital signals can result in wrong I/O card procurement and improper PLC configuration. Misclassifying SIS signals into the normal BPCS system is even more critical because safety loops require dedicated SIL rated hardware and separate architectures. Wrong fail action definitions for valves can create unsafe process conditions during shutdown situations.
Another major issue was poor revision management. When multiple departments work using different versions of the I/O list, mismatches occur between P&IDs, loop diagrams, cable schedules, and PLC software databases. This creates massive confusion during loop checking and startup. Inconsistent tagging, missing loop numbers, and improper signal grouping also increase troubleshooting time and wiring errors.
A properly reviewed and revision controlled I/O list is therefore one of the most critical deliverables in instrumentation EPC engineering projects.
Refer the below link to know more about I/O list
