Why NGR (Neutral Grounding Resistor) utilized in an Electrical System?
What is NGR (Neutral Grounding Resistor)?
An NGR (Neutral Grounding Resistor) is used in electrical power systems to limit the current that flows during a single line-to-ground fault.
Instead of allowing a very high fault current that can damage transformers, generators, motors, switchgear, and cables, the resistor safely restricts the current to a predetermined value.
This improves equipment protection, reduces arc flash hazards, and allows protective relays to detect and isolate faults effectively.
Calculator
NGR (Neutral Grounding Resistor) Calculator
How Does an NGR Work?
The NGR is connected between the transformer or generator neutral point and earth. During normal operation, almost no current flows through it.
When a phase conductor accidentally touches ground, the NGR provides a controlled path for the fault current, preventing excessive electrical stress on the system.
Advantages of using an NGR
  • Limits ground fault current to a safe level.
  • Protects transformers, generators, motors, and cables from damage.
  • Reduces arc flash energy and improves personnel safety.
  • Minimizes voltage stress on healthy phases.
  • Enables reliable operation of earth fault protection relays.
  • Reduces repair costs and improves system reliability.
Applications of NGR
NGRs are commonly installed in industrial plants, power generation stations, substations, mining operations, and petrochemical facilities, particularly in medium-voltage systems such as 3.3 kV, 6.6 kV, 11 kV and 33 kV networks where controlled neutral grounding is required.
