Why is vibration measurement very important on gas turbine and compressor
Gas turbines and compressors are high speed rotating equipment. On equipment when vibration exceeds the manufacturer limits can cause sever damage to both itself and to its associated components/parts. Hence it is important to measure and monitor vibration on the running equipment. Generally a high vibration pre-alarm and shutdown limits are set as per the manufactures recommendations.
