Why most of analog o/p devices having o/p range 4 to 20 mA and not 0 to 20 mA?
The 4-20 mA range is preferred over 0-20 mA for most analog devices in industrial settings for several practical reasons:
- Fault detection: A 0 mA reading clearly indicates a problem like a broken wire or power loss.
- Powering transmitters: The 4 mA minimum provides power for two-wire transmitters, even at minimum readings.
- Noise resistance: Starting at 4 mA gives better protection against electrical interference, especially over long distances.
- Easier calibration: The 4 mA “live zero” makes it simpler to adjust the zero point without confusing it with a fault.
- Better accuracy: Using 4-20 mA increases measurement resolution since the same 16 mA span represents the full range.
- Wide compatibility: The 4-20 mA standard is widely used, making it easier to integrate devices from different manufacturers.
These advantages make 4-20 mA loops more reliable and practical for industrial applications, which is why they’re generally chosen over 0-20 mA systems. Refer the below link for the detailed explanation
