Why is Reactive Power Essential in Power Systems?
Reactive power (measured in VAR - Volt-Ampere Reactive) is the power required to establish & maintain the magnetic and electric fields in inductive and capacitive equipment.
Although it does not perform useful work it is essential for the operation of AC power systems.
Reactive power supports voltage levels via the electrical network enabling
• Motors,
• Transformers and
• Other inductive loads to operate efficiently.
Without sufficient reactive power, system voltage drops that the equipment performance deteriorates & the risk of power outages increases.
• Maintains stable voltage via the power system.
• Enables proper operation of transformers, motors & generators.
• Reduces transmission losses & improves system efficiency.
• Enhances power factor, lowering electricity costs & equipment loading.
• Increases the overall reliability & stability of the electrical grid.
Reactive power is a fundamental component of the AC power systems.
While it does not deliver the usable energy directly it is indispensable for the voltage regulation, efficient power transmission & the reliable operation of electrical equipment.
Proper reactive power management ensures a stable, efficient & secure power network.
When reactive power increases in an electrical grid, it causes higher total current flow without delivering any useful work that strains equipment & reduces system efficiency.
