Why High Voltage for Power Transmission?
Efficient power transmission is a key factor in ensuring reliable and sustainable electrical systems.
This post explains a fundamental principle used across the power industry:
High Voltage = Low Current = Low Power Loss
Power loss in transmission lines is governed by:
P ₗₒₛₛ = I ²R
Even a small increase in current leads to significant energy loss in the form of heat.
By increasing the transmission voltage, current is reduced for the same power transfer that is resulting in:
- Reduced transmission losses.
- Lower heat generation.
- Improved overall efficiency.
- Reduced conductor size and cost.
Electricity generated at power plants is stepped up to high voltages (like 220 kV or more) for long distance transmission and then stepped down to 230V for safe usage in homes.
High voltage transmission is not just an option it is essential for efficient and economical power delivery.
