Why is DC used for control supply in switchgear instead of AC?
Switchgear panels like
• Breakers,
• Contactors,
• Protection relays
require a control supply to operate, open/close, & trip safely.
Why do we use DC for this instead of AC?
1). DC is continuous & stable
In an alternating current (AC) supply, voltage rises and falls as a sine wave, crossing 0 twice per cycle.
Ex: Suppose you are attempting to operate a trip coil (or) release relay during a 0-crossing instant, the coil might temporarily lose energy.
This can result in
• Flickering,
• Chattering, or
• Delays
in functioning.
In DC, voltage is stable and continuous – there’s no zero-crossing.
Thus, when you energize a trip coil (or) a control circuit, it remains solid & energized without any disturbance.
2). Fast & Reliable Operations
In emergency conditions (like faults, overloads, short-circuits), the trip command should work immediately.
DC ensures fast & smooth energization of coils, without worrying about fluctuating voltages (or) time.
DC control causes breakers to trip more quickly and reliably.
3). Battery Backup is Possible
DC systems can be easily saved & backed up utilizing batteries (lead-acid, VRLA, etc.).
Even if the main AC power fails (such during a blackout or serious fault), the DC battery bank maintains the protection & control circuits alive.
As a result,
• Battery banks &
• DC panels
are common in substations and major power plants.
Without DC, consider a breaker refusing to trip as AC power failed creates life-threatening.
4). Simpler & safer circuits
DC control wiring is easier as
• No frequency effects,
• No reactive components,
• No inductive reactance,
to disturb.
It’s easier to build reliable circuits using compact relays, contactors, indication lamps, & interlocks.
5). Reduced Arc Chattering
When a contact opens in an alternating current circuit, the current may break & re-strike due to zero crossing, resulting in arcing.
DC maintains consistent polarity and magnitude; when a contact opens, the current stops cleanly.
Ex: Consider pushing open a door
AC is like repeatedly pushing & pulling a door: usually forward, often backward - and it is not smooth.
DC is like pressing hard in one direction - straight and strong.
In essential tasks, such as tripping a breaker, that you want the door to fly open promptly rather than getting stuck in midpoint.
Conclusion
In switchgear, lives & equipment are dependent on swift, reliable performance. DC provides that certainty - continuous, stable, and backup energy ready to act at any time.
That is why Control Supply = DC and Operation = Reliable.
You can also follow us on [color=#CF2E2E]AutomationForum.co[/color], [url= https://www.facebook.com/instrumentation.control][color=#1E00A3]Facebook[/color][/url] and [url= https://www.linkedin.com/showcase/81532759/feed/posts/][color=#1E00A3]Linkedin[/color][/url] to receive daily Instrumentation updates.
You can also follow us on [color=#CF2E2E] ForumElectrical.com [/color], [color=#1E00A3] Facebook [/color] and [color=#1E00A3] Linkedin[/color] to receive daily Electrical updates.
