Why are Electric Motors Rated in HP or kW?
Electric motors are rated in Horsepower (HP) or kilowatts (kW) because these units represent the mechanical output power delivered by the motor shaft.
The motor power rating indicates its ability to drive mechanical loads such as pumps, fans, compressors, conveyors, and industrial machinery.
Key Technical Points:
  • Kilowatt (kW): SI unit of power used to express the motor’s rated mechanical output.
  • Horsepower (HP): Traditional unit of mechanical power commonly used in motor specifications.
  • 1 HP: Approximately 0.746 kW.
  • 1 kW: Approximately 1.341 HP.
  • Electrical Input Power: Higher than mechanical output power because of motor losses.
  • Motor Efficiency: Determines how effectively electrical input power is converted into mechanical output power.
Important: Motor HP or kW ratings generally indicate shaft output power, not electrical input power. Current consumption depends on supply voltage, power factor, and motor efficiency.
