The term ‘‘machine’’ as used in the context of a transformer might be a little deceptive because a transformer itself is not a machine.
Here’s why a transformer might be referred to as a machine:
1). Electrical Device
A transformer is an electrical machine that does certain functions as other machines do.
It alters the voltage and current quantities in an electrical circuit and hence can be classified as electrical work.
2). Mechanical Analogy
In engineering, “machine” could be used to mean any item or system that does work or has a purpose.
Transformers can be discussed as fitting this broad definition because they do the function of converting electrical energy from one voltage level to another.
3). Complexity and Operation
Regarding the definition of the term ‘transformer,’ there isn’t anything that can be easily grasped and categorized as a ‘machine with moving parts’; however, transformers do form a category of devices which consist of various parts which include windings and cores and perform their function.
Thus, one might come across the informal usage of the term “machine” in the given context.
4). Industrial Usage
In the industrial and technical fields, this term may refer in some cases to any tool that is used in the electrical or mechanical setting as far as it relates to the current topic of transformers.
To sum up, it is possible to distinguish that a transformer does not belong to machines with moving parts according to the definitions; however, in broader or industrial meaning, it can be considered as the machine due to its function and its complexity within the electrical systems.
