Which PLC uses PROFIBUS?
Which PLC Uses PROFIBUS Communication?
PROFIBUS is an industrial fieldbus that allows PLCs to exchange process data with remote I/O, drives, instruments and other plant devices. Siemens SIMATIC PLCs are associated with PROFIBUS, while other platforms support it through compatible interfaces or communication modules.
Which PLCs support PROFIBUS?
Examples include:
Siemens SIMATIC S7-300 and S7-400 with suitable PROFIBUS interfaces. S7-1200 can use CM 1242-5 as a DP slave or CM 1243-5 as a DP master.
Siemens S7-1500 configurations with supported communication hardware.
Schneider Electric Modicon platforms using a compatible PROFIBUS DP module, including M580 DP master modules.
Other PLC and PAC families may support PROFIBUS through approved modules or gateways.
Verify the exact CPU, firmware, module and role. A PLC may operate as master, slave, or both only with suitable hardware.
How it works in a plant
A PLC acting as DP master exchanges data with DP slaves such as ET 200 remote I/O, variable-speed drives, valve islands and analyzers. Import the GSD file, assign unique addresses, configure I/O sizes and select a compatible baud rate setting.
Commissioning checks
Confirm master/slave roles, addresses, cable polarity, shield bonding, termination at both physical ends and device configuration. Check bus-fault LEDs and diagnostic buffers if communication fails. A mismatch between configured and installed I/O modules can prevent data exchange.
Selection tip
For a new project, check lifecycle support, spare-module availability and integration before choosing a PLC. PROFIBUS capability depends on the complete hardware configuration, not simply the brand name.
