When you receive an Eco Loss notice in a FMR52 radar level transmitter, take these actions to resolve the problem:
- Verify Installation
- Inspect Antenna
- Check Configuration
- Signal Strength
- Interference
- Diagnostics
- Refer Manual
- Contact Support
Verify Installation: Make sure the transmitter is installed appropriately in accordance with the manufacturer’s instructions. Check the tank for any blockages or alterations that may impact signal reflection.
Inspect Antenna: Check the antenna for any material buildup, damage, or alignment issues. Clean or realign as needed.
Check Configuration: Confirm the configuration options, such as tank dimensions, material qualities, and measurement range. If the settings differ from the actual program, adjust them.
Signal Strength: Evaluate the signal and noise levels. Poor signal strength may suggest a problem with the environment (or) the installation.
Interference: Check for sources of EMI that could disrupt the radar signal. Relocate or protect the transmitter as necessary.
Diagnostics: Use the transmitter’s diagnostic features to perform a self-check. Follow any recommendations based on diagnostic results.
Refer Manual: Check the instruction manual for precise ways to troubleshoot Eco Loss notifications.
Contact Support: If the problem continues, please contact the manufacturer’s technical support for assistance.
