What range is given in the level transmitter of a 10-meter tank?
The range provided by a level transmitter for a 10-meter tank would typically be specified in terms of the minimum and maximum levels it can accurately measure within that tank.
For instance, if the transmitter is designed to measure the level of liquid within a tank, its range might be something like 0 to 10 meters. This means it can accurately measure levels from the bottom of the tank (0 meters) to the top (10 meters).
It’s worth noting that different level transmitters may have different ranges depending on their design, technology, and intended application.
