The device used to protect the gauge from pulsating pressur is snubber. A pressure type known as pulsating pressure changes or fluctuates quickly over time. Pressure gauges may be harmed as a result, giving up erroneous readings or possibly failing altogether. Snubbers, which are meant to shield gauges from these variations, are utilised. To reduce the pulsations, a tiny part called a snubber is put between the gauge and the pressure source. It functions by lowering the flow of the substance being monitored, which lowers the frequency and magnitude of pressure changes. A snubber can be constructed from a number of materials, but the most typical model has a tiny piston that hardly moves inside a cylinder. The piston oscillates back and forth when pressure pulsations pass through the snubber, helping to absorb the energy of the oscillations and smooth the pressure signal before it reaches the gauge. When pressure readings must be extremely exact or the pressure source is known to have substantial pulsations, using a snubber is crucial. Without a snubber, the gauge may deliver inaccurate readings and the monitored equipment may not operate as intended
