What is the use of a V-ball valve?
A V-ball valve is a type of control valve designed to provide precise flow control. The āVā shape in the ball creates a variable orifice that allows for better flow control characteristics compared to standard ball valves. Here are some key uses:
Precise Flow Control:
V-ball valves offer precise throttling capabilities, making them ideal for applications where accurate flow regulation is needed, such as in chemical processing, water treatment, and HVAC systems.
High Turndown Ratio:
They provide a high turndown ratio, allowing for fine control over a wide range of flow rates. This makes them suitable for processes that require both high and low flow rates.
Durability in Harsh Conditions:
V-ball valves are designed to handle abrasive or viscous fluids, making them useful in industries like oil and gas, pulp and paper, and mining.
Quick Operation:
They can be actuated quickly and offer fast shut-off capabilities, which is essential in emergency situations or when rapid response is needed in a process.
