What is the SIL rating of the Bently Nevada 3500 system?
In process industries, the Bently Nevada 3500 system is a common way to protect machinery and keep an eye on its status. It is made to keep an eye on things like vibration, displacement, and speed in machinery that is rotating. The system meets API 670 standards and is often used to keep an eye on and protect important assets including steam turbines, gas turbines, and compressors.
SIL Rating Clarification
There is no common SIL rating for the whole 3500 system. Instead, Safety Instrumented Systems can employ some parts of the system up to SIL 1 or SIL 2, depending on how they are set up and certified. IEC 61508 and IEC 61511 standards say that the actual SIL rating depends on the whole safety loop, which includes sensors, logic solvers, and final control elements.
Field Application Insight
The 3500 system makes warnings and trip signals based on vibration limits in real-world plant settings. But most of the time, a dedicated SIS or ESD system does the ultimate shutdown. Before giving any SIL level, engineers must check the module certification, proof test intervals, and system design. If you assume SIL compliance without fully validating the loop, you could put yourself in a lot of danger and fail audits.
