What is the role of Raspberry Pi in IoT?
Role of Raspberry Pi in IoT
  • The Raspberry Pi is a small, powerful computer designed for IoT applications. With built-in I/O ports, Wi-Fi, Bluetooth, Ethernet, and USB peripherals, it can easily interface with various IoT devices.
  • Due to its compact size, it eliminates the need for bulky equipment like laptops or PCs, offering a portable solution for connecting to the IoT ecosystem.
  • Its versatility allows it to handle diverse tasks, from home automation to complex industrial systems, while its open-source nature makes it an attractive option for developers.
Uses of Raspberry Pi in IoT Devices
  • Raspberry Pi is ideal for powering IoT devices due to its low cost, small form factor, and robust connectivity options.
  • It can be integrated into a wide range of projects, from mobile apps and desktop websites to surveillance cameras and industrial monitoring systems.
  • The Raspberry Pi’s compatibility with the Linux operating system and extensive developer support makes it easy to process sensor data and control devices.
  • Whether for hobbyists or businesses, the Raspberry Pi provides an efficient, scalable platform for creating connected products and networks on a budget.
