What is the Reynolds number range for orifice plate?
The kind of opening employed and the properties of the process fluid determine the Reynolds number range for an orifice plate. A dimensionless value called the Reynolds number (Re) shows whether fluid flow is laminar or turbulent and greatly influences the accuracy and dependability of differential pressure flow measurements employing orifice plates.
The advised Reynolds number range is above 2000 for concentric square-edge orifice plates, which are the most prevalent kind. This guarantees the flow is turbulent enough for precise and predictable differential pressure creation. These orifice plates are appropriate for clean liquids and clean gasses.
The relevant Reynolds number range is usually between 200 to 10,000 for concentric quadrant-edge or conical-edge orifice plates intended for viscous or low Reynolds number flows. In low-velocity, high-viscosity settings where conventional sharp-edge orifices may not operate consistently, these plates perform better.
To preserve precision and minimize the impact of deposits or clogs, eccentric or segmental orifice plates used with filthy or slurry-laden fluids need a greater Reynolds number. Typically, these plates are utilized in flows with Reynolds numbers over 10,000.
Maintaining flow measurement accuracy depends on choosing the correct orifice plate depending on fluid condition and Reynolds number.
