What is the Range of the pH Transmitter?
- The pH levels that a pH transmitter can reliably measure and communicate are usually referred to as its range.
- To determine a solution’s acidity or alkalinity, pH transmitters are utilized.
- Most pH transmitters have a typical pH range of 0 to 14, with 0 being extremely acidic, 7 being neutral, and 14 being extremely alkaline. Narrower or broader ranges, however, may be available for some specialist pH transmitters based on the demands of the particular application.
- To find out the pH transmitter’s exact range and accuracy, it is essential to refer to the specifications supplied by the manufacturer.
- A current output signal, usually referred to as a 4-20 mA signal, is frequently used by pH transmitters. In this arrangement:
The lowest pH value (e.g., pH 0) corresponds to 4 mA.
The highest pH value (e.g., pH 14) corresponds to 20 mA.
- The stability of this current signal against signal decrease over long distances makes it commonly used in industrial settings.
- It is essential to ensure that the output signal range of the transmitter corresponds with the input specifications of the control system or receiving equipment.
- In order to ensure that the whole pH range is accurately represented within the specified output signal range, calibration and scaling processes could be required.
