What is the purpose of Surge Arresters on 2 Sides of a Transformer?
Surge arresters prevent against overvoltages by being installed on both sides of a transformer (high-voltage and low-voltage).
Surge arresters are also installed on both the HV and LV sides to protect the transformer from transient overvoltages & lightning surges from either direction.
Here’s the 4 reason both sides need them:
1). High-Voltage Side Protection
2). Low-Voltage Side Protection
3). Internal Voltage Transfer
4). Coordination with Grounding
Protects transformers from lightning and power system surges.
Overvoltages can still arise due to
  • Internal switching,
  • Back-feeding, or
  • Surge flowing
through the transformer.
A surge arrester protects downstream equipment and transformer windings.
Magnetic coupling can cause a surge to cause a high voltage on other side.
Arresters on either side help to reduce these transferred surges.
Arresters on both sides ensure adequate
  • Voltage clamping and
  • Safe dissipation of surge energy to ground.
You can also follow us on [color=#CF2E2E]AutomationForum.co[/color], [url= https://www.facebook.com/instrumentation.control][color=#1E00A3]Facebook[/color][/url] and [url= https://www.linkedin.com/showcase/81532759/feed/posts/][color=#1E00A3]Linkedin[/color][/url] to receive daily Instrumentation updates.
You can also follow us on [color=#CF2E2E] ForumElectrical.com [/color], [color=#1E00A3] Facebook [/color] and [color=#1E00A3] Linkedin[/color] to receive daily Electrical updates.
