What is the primary purpose of applying a coating to copper busbars in electrical panels or busducts?
The major objective of adding a coating on copper busbars in the electrical panels (or) busducts is to prevent oxidation & corrosion which helps to maintain low electrical resistance at connection points & assures the electrical system’s long-term stability.
[color=#ff0000] Important Reasons for covering Copper Busbars [/color]
Corrosion Prevention: Over time, copper generates an oxide layer, which increases contact resistance and causes joint overheating. Coating protects against this.
Improved Electrical Conductivity: A clean, shielded surface allows for improved current flow with less energy loss.
Enhanced Mechanical Protection: The coating lowers wear and tear caused by vibration, moisture & environmental causes.
Safety: Some coatings give greater insulation, lowering the possibility of an inadvertent short circuit.
Aesthetics & Identification: Coating can also aid with color coding in panels to identify phases.
  • Tin plating,
  • Silver plating,
  • Nickel plating &
  • Insulating varnish
are all common coatings that depend on the application and atmospheric conditions.
[color=#ff0000] Comparsion [/color]
Coating Type Primary Purpose Advantages Disadvantages Typical Applications
Tin Plating Reduces the risk of oxidation and corrosion Economically rational. An excellent resistance to corrosion. Preserves a low electrical contact resistanceSurface that can be soldered Because it is a softer metal, it might wear out over time.Not suitable for temperatures that are really high Switchboards, busducts, LV/MV panels & interior substations.
Silver Plating Exceptional conductivity and protection against corrosion Conductivity of electricity that is the highest among all metals. Exceptional for drops of high current and low voltage when used. Unaffected by oxidation in the majority of settings used Quite pricey. In conditions that are high in sulfur, it may tarnish. Important industrial systems, power plants, and high-voltage switchgear
Nickel Plating Protection against corrosion and wear Extremely hard surface. Excellent in settings that are both corrosive and high in temperature. Lasts for a long time and protects against unintentional short circuits. It is more expensive than tin. The conductivity is slightly lower than that of copper. Dangerous workplaces, chemical factories, and maritime uses
Epoxy/Insulating Varnish Insulating electrical systems and protecting against corrosion A barrier against moisture; the ability to color code It is not possible to use it on touch surfaces. Thermal conductivity that is restricted. Components such as covered busbars, compact busducts, and phase separation
Bare Polished Copper (No Coating) (polished for the initial conductivity) The answer is none. The highest possible conductivity initially. A low cost Rapid oxidation occurs. There is a greater demand for maintenance. Indoor dry environments & temporary systems & settings:
