what the function of key phasor ?
The keyphasor is an electric pulse, or trigger, which is derived from a point on a rotating shaft. It serves as a zero phase reference for determining where imbalance is on a rotor. A Keyphasor signal is a once-per-turn or multiple-event-per-turn pulse from a rotating shaft or gear used to provide a precise timing measurement. The module receives input signals from proximity probes or magnetic pickups and converts the signals to digital Keyphasor signals that indicate when the Keyphasor mark on the shaft coincides with the Keyphasor transducer.
