Electric Actuator Ball Valve
An electric actuator ball valve is a type of valve that utilizes an electric actuator to regulate the flow of fluid through it. This device combines the functionality of a ball valve, recognized for its rapid on/off operation, with the automation capabilities of an electric actuator.
How Electric Actuator Ball Valve Works?
Electrical Actuator
This system’s main component is the electric actuator, which turns electrical energy into mechanical motion. When an electrical current is delivered, the actuator’s motor produces rotational force.
Gear Mechanism
The rotating motion is conveyed by a set of gears. The gears lower the motor’s high-speed output while increasing torque, which is required to operate the valve properly.
Valve Operation
Connect the actuator to the ball valve’s stem. The actuator turns, causing the ball inside the valve body to revolve. The ball features a hole in its center; when aligned with the flow route, it allows fluid to pass through (open position); when rotated 90 degrees, it blocks the flow (closed position).
Control Features
Electric actuators can be equipped with limit switches & control circuitry for precise operation. Electric actuator ball valves are commonly employed in industrial operations requiring precise flow control due to their remote control and automation capabilities.
Application of Electric Actuator Ball Valve
- Controlling water flow in treatment plants.
- Chemical processing refers to the safe and efficient management of chemicals.
- Used to regulate air & fluid flow within heating & cooling systems.
You can also follow us on [color=#CF2E2E]AutomationForum.co[/color], [url= https://www.facebook.com/instrumentation.control][color=#1E00A3]Facebook[/color][/url] and [url= https://www.linkedin.com/showcase/81532759/feed/posts/][color=#1E00A3]Linkedin[/color][/url] to receive daily Instrumentation updates.
You can also follow us on [color=#CF2E2E] ForumElectrical.com [/color], [color=#1E00A3] Facebook [/color] and [color=#1E00A3] Linkedin[/color] to receive daily Electrical updates.
