Steam boilers are suitable for the following fields:
Industrial field:Steam boilers are widely used in steam supply in industrial production processes such as factories, chemical plants, power plants, textile mills, paper mills, food processing plants, etc. For heating, cooking, drying, disinfection and other processes.
Power generation field: Steam boiler is the most commonly used type of boiler in power plants. It generates steam by burning fuel and drives the steam turbine to generate electricity.
3.Central heating: Steam boilers can be used in central heating systems to heat buildings through the heat transfer of steam. This method is common in large buildings, factories, office buildings, schools, hospitals and other places.
4.Greenhouse planting: Steam boilers can provide heat energy to the greenhouse to maintain the temperature and humidity in the greenhouse and create a suitable planting environment.
In short, steam boilers are suitable for industrial production, energy supply, heating and hot water supply that require large amounts of heat energy and steam.
Hot water boilers are suitable for the following areas:
1.Industrial field: Hot water boilers are widely used in heating, heating and hot water supply in industrial production processes, such as chemical plants, textile factories, food processing plants, etc.
2.Residential life: Hot water boilers can provide hot water supply for families, especially in cold areas, including bathing, washing, heating, etc., and can also provide hot spring and hot water supply for hot spring resorts and swimming pools.
3.Commercial field: Hot water boilers are widely used in hot water supply in hotels, office buildings, shopping malls, hospitals, schools and other places, and can also be used for heating and hot water supply in transportation vehicles such as ships, trains and airplanes.
4.Agricultural field: Hot water boilers can be used for heating and hot water supply in agricultural greenhouses, farms and other agricultural places.
In short, hot water boilers are suitable for any place and field that requires heating and hot water supply.
Biomass boilers are suitable for the following fields:
1.Industrial field: Biomass boilers can use biomass resources such as crop straw and wood waste to provide heat energy for industrial production, such as pulp mills, wood processing plants, food processing plants, etc.
2.Residential life: Biomass boilers can be used as heating boilers for residents, for home heating and hot water supply, using biomass fuels such as wood chips and crop straws for heating. Biomass boilers can also be used as part of urban heating systems, using biomass fuel to provide heat energy supply.
3.Agricultural field: Biomass boilers are suitable for the agricultural field. They can use agricultural waste such as crop straws and livestock and poultry manure as fuel for energy recovery and utilization, and can be used for greenhouse heating, farm heating, etc.
4.Greenhouse planting: Biomass boilers are suitable for greenhouse planting, which can provide heating and carbon dioxide supply in the greenhouse and promote plant growth.
5.Wood processing: Biomass boilers can be used in wood processing plants to use wood chips, sawdust and other waste as fuel to provide heating and thermal energy supply.
In short, biomass boilers are suitable for various fields that require heat energy supply, especially in agriculture, industry and residential fields. They have broad application prospects.
