Explain the difference between the single acting and double acting pneumatic actuator
Single action in a control valve is driven by the air output of the control valve positioner on one side (side open or close) while the other side is moved with the aid of a spring or a membrane. … The double acting actuator is the actuator that only use piston as its element to operate the valve.
