Explain the difference between line voltage and phase voltage
Line voltage is the voltage between two phases and phase voltage is the voltage between phase and neutral, the line voltage is maximum two phases 415 to 440, and phase voltage between phase and neutral more about 210 to 240 volts. Line voltage is between the phases while phase voltage is single-phase ( Live and neutral)
Phase voltage is a potential difference between a line (example: red, yellow, or blue phase) and neutral, it’s 240v while line voltage is a potential difference between two lines (example: yellow and blue phase)
