| The maximum current that a particular load may drain from the circuit is referred to as full-load current. |
The rated current is the current listed on the name plate by the manufacturer. It is the most current that the device can withstand. |
The nominal current is the current with the highest efficiency. |
| Full load current usually refers to the current drawn a motor, which will draw a different amount of current depending on the mechanical load applied to its output. Full load current is drawn when the output is subjected to its maximum rated load. |
A conductor, a source of power, or a control device like a switch that is capable of withstanding currents up to a certain limit. |
When a device like a motor operates under its intended load, which will be smaller than the maximum permitted load in a conservatively constructed system. |
| The rated full load current (FLC) is the value given by the manufacturer when tested under ideal circumstances. |
Motor windings are intended for carrying the rated current in normal operation and somewhat more for shorter durations. |
It is the current taken by the motor while generating the rated mechanical (physical) output at its shaft. |
| The rated full load current (FLC) is the maximum that should ever draw via a source like an outlet or a generator. |
The rated current is calculated from ideal condition of the device in normal input supply. |
It must always be less than the device’s rated current. |
| When several outputs impact one other, the outputs cannot draw the full load current at same time. |
The rated current is considered “standard” since “full load current” only allows for immeasurable combinations. |
The nominal current in amperes that each contact may transfer continuously & simultaneously. |
