Float chargers and boost chargers are both used in industrial battery charging systems, but their functions are different based on battery condition and operational requirement.
A float charger is mainly used to maintain the battery in fully charged condition during normal operation. It continuously supplies a small charging current to compensate battery self-discharge and connected dc load. Float charging helps improve battery life, maintain backup readiness, and provide stable dc supply for substations, telecom systems, relay panels, and industrial dc applications.
A boost charger is used when the battery requires faster charging after discharge conditions or power failure situations. Boost charging provides higher charging current and voltage compared to float charging. It helps batteries recover quickly and restores backup capability within shorter duration.
In many industrial applications, float cum boost chargers are used because they automatically switch between float mode and boost mode depending on battery condition and operational requirement. These systems are commonly used in substations, power plants, telecom infrastructure, industrial automation systems, and utility applications.
Important benefits of industrial float and boost chargers:
- Stable dc output support
- Reliable battery charging performance
- Improved battery operational life
- Faster battery recovery after discharge
- Reduced operational interruption
- Better emergency backup reliability
- Suitable for industrial and utility operations
Proper charger sizing and battery compatibility are important for reliable dc system performance. Incorrect charging configuration can reduce battery life, create dc instability, and affect operational continuity during emergency conditions.
Industrial battery charger systems should be selected based on:
- Battery bank voltage
- Ah capacity requirement
- Dc load condition
- Backup operational requirement
- Industrial application type
- Future expansion requirement
Vivatek provides industrial float chargers, boost chargers, float cum boost chargers, smps chargers, and thyristor charger systems for substations, power plants, telecom infrastructure, and industrial dc applications across india.
