What is the difference between continuity test and resistance test?
Here is a clear comparison table between Continuity Test and Resistance Test utilized in electrical testing:
Parameters Continuity Test Resistance Test
Definition Checks whether a complete electrical path exists (open or closed circuit). Measures the exact opposition to current flow in ohms (Ω).
Purpose To verify circuit continuity (no break in wire or connection). To measure the resistance value of a component, conductor, or circuit.
Output Result Gives indication as Beep / No Beep, or 0 / OL. Gives numerical value in Ohms (Ω), kΩ, or MΩ.
Accuracy Qualitative test (only confirms presence or absence of continuity). Quantitative test (provides exact resistance value).
Test Voltage Very low voltage (typically 2–5 V from multimeter). Slightly higher but still low voltage from multimeter test circuit.
Measurement Range Used for very low resistance (typically 0–50 Ω). Used for wide range (from milliohms to megaohms depending on instrument).
Indication Method Audible beep and visual indication. Numerical display only.
Instrument Used Multimeter in continuity mode. Multimeter, Micro-ohmmeter, or Ohmmeter.
Main Application Checking wires, fuses, switches, and connections. Measuring resistor value, winding resistance, cable resistance.
Decision Type Pass/Fail test. Analytical measurement.
Example Checking if a cable is broken or intact. Measuring motor winding resistance (e.g., 2.5 Ω).
Speed Faster test. Slightly slower due to measurement calculation.
