What is the difference between accuracy and tolerance
How is accuracy different from tolerance
Accuracy determines how close your measurement is to the actual signal value. Tolerance is the pre-determined, acceptable level of that variation in precision. So Accuracy is the closeness of measured value with the true value… tolerance is the acceptable level of variation
