What is the Difference Between a Synchronous Motor and an Induction Motor?
Synchronous motors and induction motors are the two most widely used AC motors in industrial and commercial applications. While both convert electrical energy into mechanical energy, they differ significantly in operating principle, speed characteristics, starting method, efficiency, and applications. Understanding these differences helps engineers select the right motor for specific loads and operating conditions.
What Is a Synchronous Motor?
A synchronous motor operates at a constant speed that is exactly synchronized with the supply frequency. Its rotor rotates at the same speed as the rotating magnetic field produced by the stator. The rotor requires DC excitation or permanent magnets to create the magnetic field.
What Is an Induction Motor?
An induction motor, also known as an asynchronous motor, operates by electromagnetic induction. The rotor current is induced by the stator’s rotating magnetic field, allowing the rotor to rotate slightly slower than synchronous speed. This speed difference is known as slip.
Difference between Synchronous Motor and Induction Motor
Parameter Synchronous Motor Induction Motor
Operating Principle Rotor locks with stator magnetic field Rotor current induced by electromagnetic induction
Speed Runs exactly at synchronous speed Runs below synchronous speed due to slip
Slip Zero Always greater than zero
Starting Not self-starting (requires starter or auxiliary method) Self-starting
Rotor Excitation Requires DC excitation or permanent magnets No external rotor excitation required
Power Factor Can operate at leading, lagging, or unity power factor Generally operates at lagging power factor
Efficiency Higher, especially at constant loads High but generally lower than synchronous motors
Speed Regulation Excellent Good, but varies slightly with load
Construction More complex Simpler and rugged
Maintenance Higher due to excitation system Lower maintenance
Cost Higher initial cost More economical
Common Applications Compressors, pumps, synchronous condensers, power factor correction Fans, pumps, conveyors, compressors, machine tools
