Temperature Transmitter
There are two ways to get the reading from the temperature device to its final destination
1.Attach the end unit directly to the low -level signal (Ohm or mv) which may or may not require the use of sensor extension wires (thicker,fragile and expensive) depending upon the distance from the sensor to the meter.
2.Install a temperature transmitter to take the low level signal and convert it into something that can be transmitted long distance
A temperature transmitter reads the thermocouple or RTD inputs and outputs a high-level analog or digital signal (such as 4-20 ma current loop or Modbus serial communications
