What is Poppet valve and How it works?
What is a Poppet valve?
A poppet valve (also known as a mushroom valve) is a type of valve that controls the amount and timing of gas or vapour flow into an engine.
It is made up of a hole or open-ended chamber, which is usually round or oval in cross-section, and a stopper, which is usually a disc form on the end of a shaft known as a valve stem. The valve face of this plug is normally ground at a 45° level to seal against a corresponding valve seat ground into the rim of the chamber being sealed. To maintain alignment, the shaft passes via a valve guide.
How does a poppet valve work?
Poppet valves are frequently found in pressure control equipment and applications. They are directional control valves, and they are often high-flow fast-acting valves. This is owing to the large flow channels via the valve’s primary body. Poppet valves can typically be opened quickly, making them ideal for use in engines.
Poppet valve working principle
Consider the poppet valve as a plug-in sink. When you remove the stopper, the flow path expands quickly and dramatically. The broad opening of the poppet valve allows media to travel swiftly and easily through the valve.
4StrokeEngine_Ortho_3D_Small
Poppet valves in a typical overhead camshaft engine
Poppet valves are typically composed of a flat disc of metal connected to a long rod known as the valve stem. When the stem is not being pushed on, a spring closes the valve. Depending on the application, the stem can be moved by a variety of actuators, including a pilot, manual, mechanical, or solenoid operator.
Poppet valve design and usage
Poppet valves are constructed and composed of a metal flat disc and a valve stem. The valve stem is used to push down on the valve to open it, and a spring is used to close it when the stem is not pulled on. Depending on the application, the stem can be moved by a variety of actuators, such as a pilot, manual, mechanical, or solenoid operator.
These valves have a slender stem and mushroom-shaped head and work in a piston engine by opening and closing the intake and exhaust ports in the cylinder head. The engine moves the valves by pushing on the stems with cams and cam followers. The valve lift and speed at which the valve is opened are determined. The shape and position of the cam determine the valve lift and the speed at which the valve is opened.
Application of Poppet Valve
The poppet valve does not require lubrication, so you can choose it without worrying about the chemical compatibility of the lubricant with different fluid applications. This also qualifies them for use in any system that requires clean, dry air, such as a medical application. Poppet valves have a self-cleaning propensity because the huge relative valve opening produces a large flow across it, sweeping away contaminates that reside on the valve’s surface. Poppet valves are often used in single-acting cylinder engines for pressure holding and pressure release. They are also employed in the loading and unloading of positive displacement pumps. Poppet valves can also be used as relief valves in air tanks.
  • Poppet valve can be used in various fluid applications
  • It can be used in single-acting cylinder engines
  • It is also used in the loading and unloading of positive displacement pumps
  • Used as relief valves in air tanks
Advantages and Disadvantages of Poppet Valves
Advantages of Poppet Valves
  • It has a high flow rate due to the bigger interior surface.
  • Because the exhaust port is covered by the poppet before the flow, the positions can be controlled properly.
  • Product life is high
  • The poppet valve has a very fast response time, therefore the port will open quickly during actuation.
  • These valves are dust and grime-resistant.
  • Low maintenance and cost-effective
  • The biggest downside of these valves is the large amount of actuation power needed to operate them.
  • This strong actuation force is required to resist the force exerted by both the built-in reset spring and the compressed air.
