What is meant by Symmetrical Components?
Voltages and currents in a three-phase power system can become unbalanced as a result of faults, load imbalance (or) equipment failure. To analyze these conditions, πΊππππππππππ ππππππππππ are utilized:
π). π·πππππππ πΊπππππππ
Three voltages or currents of equal amplitude.
Theyβre separated by 120Β°.
Rotate the same way as the original system.
Represents the electricity systemβs regular operating condition.
π¬x: A healthy system has a balanced positive sequence of phase voltages (Va, Vb, Vc).
π). π΅πππππππ πΊπππππππ
Three voltages or currents of equal magnitude.
Separated by 120Β°, but spin in the opposite direction as the original arrangement.
Caused by imbalanced faults (such as line-to,line or unbalanced loads).
Harmful to motors & generators due to increased temperature.
π¬x: A single-phase-to-ground fault causes negative sequence components.
π). ππππ πΊπππππππ
Three voltages (or) currents have identical magnitude and phase (0Β° shift).
Typically connected with earth faults.
Exists when there is a return path (for example, through neutral/ground).
π¬x: A single-line-to-ground fault in a system with a grounded neutral will result in high zero-sequence current.
