What is Corona Effect?
Explain the corona effect in an electrical system
The phenomena of CORONA EFFECT occurs on high voltage transmission lines.Off course produce due to ionisation around the conductor caused by electrical discharge.In this effect a blue light and a hissing audible Sound is produce not VIBRATION.One can easily be observe Corona Effect on transmission line by their eyes and can listen the hissing sound the effect is more when weather has more moisture contents in air
What is meant by corona loss?
Ozone gas is produced by the development of corona, that chemically reacts with the conductor, causing corrosion. Corona loss refers to the amount of energy dissipated in a system as a result of the Corona effect.
