When a user program (or) HMI sends data on demand, it uses a class 3 connection.
Class 3 connections are commonly utilized in Logix 5000 systems to transmit massive amounts of low-priority data.
Class 3 communications include
Logix CIP Data Table MSG instructions &
FTLinx Data Read operations.
Class 3 connections are opened & closed as needed.
A Class 3 connection can be ended manually by the originator or automatically after a specified timeout interval.
Opening a Class 3 connection makes use of a disconnected communication resource in the PLC.
If no resources are accessible, the consumer will receive an error message from the connection originator.
In current Logix 5000 systems, Class 3 communication is handled by a separate Communications core in the controller processor.
