Motor Control Center (MCC)
A Motor Control Center (MCC) is an important part of electrical power distribution networks, generally utilized in industrial and commercial settings to regulate and protect electric motors. It is made out of a centralized assembly that incorporates several enclosed parts, each with motor control units & a shared power bus. This system enables effective control and monitoring of several motors from a single location, thereby improving operational efficiency & safety.
MCC Components
MCCs often have the following components:
Motor Control Units
These units contain switches & circuits that control individual motors, such as starters, relays, and contactors.
Horizontal Bus
The horizontal bus connects the primary power source across the length of the MCC to the various vertical bus sections.
Vertical Bus
Vertical Bus is also known as the power bus, it allows power connections to many starter units within the MCC.
Control and Monitoring Equipment
Modern MCCs may include programmable logic controllers (PLCs), variable frequency drives (VFDs), & soft starters to improve motor control and diagnostics.
Advanatages of Using an MCC:
The advantages of using an MCC include:
Centralized control enables the management of several motors from a single place, simplifying operations & maintenance.
Minimizes electrical dangers by limiting human connection with active equipment.
Integrating VFDs can result in significant energy savings by adjusting motor speed based on demand.
Components are designed for easy access, which allows for faster repairs and inspections.
Application of MCC
MCCs are widely used in applications where a large number of motors must be controlled, such as industrial plants, water treatment facilities, & HVAC systems. They provide an organized way to regulating electrical loads while maintaining motor safety and reliability.
